Date/Time: Wed, 25 Nov 2026 20:19:35 +0000
Flatten order
View Count: 580
[2026-07-06 18:43:41]
Jimmyy - Posts: 358
Hi, Could you guys please add just "Flatten" order in chart trade menu?
There is Flatten and cancel , I am looking for it to just Flatten and not cancel any open orders
Thank you
[2026-07-06 21:29:19]
John - SC Support - Posts: 48658
We have set this as a "Feature Request", as there is not an option for "Flatten" in the current options for the "Chart Trade Menu".
We do want to point that there is a Control Bar button option for this, it is listed as "Trade Flatten Only".
There is also a Keyboard Shortcut that you can setup listed as "Flatten Only".
[2026-07-07 12:55:15]
Jimmyy - Posts: 358
I specifically want it in the chart trade menu. I hope it is added asap.
Thank you
[2026-07-09 13:04:52]
Jimmyy - Posts: 358
one more thing - for the flatten and cancel order , does it first cancel the orders and the flatten or does it flatten first and then cancel the orders?
I feel there is a slight delay in this order which i think its because it first cancels the orders and then flattens.
[2026-07-09 15:29:23]
They all happen at the same time. Unless you have the following setting set to "Yes":
Global Trade Settings Windows: Hold Market Order Until Pending Cancel Orders Are Confirmed (Global Settings >> General Trade Settings >> General)
[2026-08-07 17:31:06]
Jimmyy - Posts: 358
Has this been added to any of the new versions ?
[2026-11-03 15:46:40]
Jimmyy - Posts: 358
Can you'll also please add just a reverse order type (specifically in control bar) . Currently there is revere and cancel.
Thank you.
I hope both the above order types get added soon.
Date Time Of Last Edit: 2026-11-03 15:54:32
[2026-11-16 15:42:02]
Jimmyy - Posts: 358
If this is too much to do then can you'll just add a yes or no setting in chart trade settings to let open orders cancel at flatten/reverse ?
