Date/Time: Tue, 06 Oct 2026 17:30:00 +0000
Chart DOM — text color for Market Depth Quantity High Threshold
View Count: 226
| [2026-07-06 18:39:45] |
| cvltr95 - Posts: 4 |
Version 2915. Graphics Settings >> ChartDOM has background color settings for Bid/Ask Market Depth quantities exceeding the High Threshold. I do not see a corresponding setting for the text color of those cells — the depth quantity text color appears to apply to all levels equally. Is there a way to color the quantity text only for cells exceeding the High Threshold? Or is it correct that the text color is global for all depth quantities? |
| [2026-07-06 18:42:13] |
| John - SC Support - Posts: 48121 |
There is not a separate coloring option for the text for the Bid/Ask depth quantities that exceed the high threshold. There is just the background coloring. We have noted this as a Feature Request to have a separate text coloring option for Bid/Ask depth quentities that exceed the high threshold in addition to the background. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
