Date/Time: Tue, 06 Oct 2026 17:30:00 +0000
Initial Balance Settings
View Count: 240
[2026-07-06 14:40:36]
User531621 - Posts: 144
Folks, can you help me get the IB took working correctly. I put it up this morning and so far its not on the chart. It is currently 7:40 AM PST. It did however put the levels from the 2nd but they are incorrect. They are not from 9:30 AM to 10:30 AM.
These are the settings:
Start / end is correct, noted above
Weekly days: 2
Intraday # of min: 15
Period end as minutes from session start: 15
Ideally I am looking for the start- 9:30 AM / end 10:30 AM
Thank you!
[2026-07-06 16:26:36]
John - SC Support - Posts: 48121
If you want the Initial Balance from 09:30 to 10:30 every day, then set the Initial Balance study as follows:
- Initial Balance Type: Daily
- Start Time: 09:30
- End Time: 10:29:59
- Start End Time Method: Use Start/End Time
Set other items as you want. Note that "Weekly: Number of Days" has no impact when using a Daily Initial Balance Type.
Refer to the information for the Initial Balance study here:
Initial Balance
[2026-07-06 17:32:31]
i set it to PST: 6:30 to 7:29. that did the trick.. Thank you!!!!
