Date/Time: Thu, 08 Oct 2026 01:51:39 +0000
[Programming Help] - ACSIL full market depth stopped after upgrade from v2909
View Count: 545
[2026-07-06 13:00:59]
trad - Posts: 52
My custom ACSIL study used to read full market depth correctly on v2909 using:
`sc.UsesMarketDepthData = 1`
`GetBid/AskMarketDepthNumberOfLevels()`
`GetBid/AskMarketDepthEntryAtLevel()`
After upgrading Sierra, the study’s BOOK/PRESS depth signals went blank. The Market Depth Window still shows depth, but ACSIL full-depth reads no longer return usable multi-level data.
I rebuilt the study with the newer headers after the v2911 `s_MarketDepthEntry` change from `float` to `double`. The rebuilt DLL is definitely running, but full-depth reads still fail. I added diagnostics and the study now only works via a level-1 fallback using `GetSymbolDataValue(..., SubscribeToMarketDepth=true)`.
Message Log also shows:
`SC Data with Depth | Logon error received from server: Data service (scdtcdatawithdepth) is disabled or unsupported.`
Is there something I can do to fix this?
Thanks.
