Date/Time: Sun, 29 Nov 2026 14:31:52 +0000
Missing rows in Export Bar Data to Text
View Count: 481
| [2026-07-04 21:05:29] |
| maxima120 - Posts: 177 |
I opened NQH22-CME-BIDASK chart, set bar interval to Number of trades = 1. from menu Edit -> Export Bar Data to Text. So I expected tick by tick export. I got the file. When I started to go row by row in scid file - i found 4 missing rows in just first 14 rows - ie they exist in .scid but not in .txt export Any ideas why ? what is the ground truth here - .scid or .txt ? (perhaps you filter out some ticks because they are bad? I cant see why they are different, the date time seems in order) Also Open field is not populated at all (4 x 0x00 bytes) - is it expected? Also it seems Hign == Last for asks and Low == Last for bids, but the opposite value ie Low for asks and High for bids populated with some price that I cannot reconcile. what is it? P.S. i just want tick by tick BBO Date Time Of Last Edit: 2026-07-04 21:32:39
| [2026-07-08 21:37:44] |
| Sierra_Chart Engineering - Posts: 25523 |
We need some time to test this.
| [2026-10-13 05:17:05] |
At this time we are marking this as resolved. We have no time to allocate this or get involved in this. And we have no further comment. We simply have no time to allocate to it. It would be many years before we even get to it. And we do not believe there is any problem either. There is some explanation but we do not have time for the analysis. Yes: Also Open field is not populated at all (4 x 0x00 bytes) - is it expected? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
