Date/Time: Tue, 24 Nov 2026 01:13:00 +0000
Market Depth Historical Graph - specific candle causes study's levels to disappear
View Count: 297
[2026-07-01 14:55:18]
GrabbenD - Posts: 3
Tested on MESU26-CME @ 1 Min chart with Denali datafeed
When today's (2026-07-01) 08:36 (New York (-5 EST/-4 EDT)) candle is visible on the chart, it causes all the levels from 'Market Depth Historical Grap' study to become barely visible (with the default settings).
The levels are almost invisible until I scroll the chart away from the 08:36 candle. This particular candle shows a very bright yellow rectangle, so there must be an abnormal amount of volume in that exact spot which causes rest of the levels to become dull/dimmed.
Are there any workarounds/solutions to mitigate this problem now and from happening in the future?
Verified this is reproducible on following versions:
- 2924
- 2926
Date Time Of Last Edit: 2026-07-01 15:47:39
imagemarketdepthlevels-normal.png / V - Attached On 2026-07-01 15:47:25 UTC - Size: 18.48 KB - 87 views
imagemarketdepthlevels-08-36.png / V - Attached On 2026-07-01 15:47:29 UTC - Size: 15.23 KB - 80 views
[2026-07-01 19:22:58]
John - SC Support - Posts: 48633
Your conclusion is correct. There would be a very high level where that yellow is showing.
There are a number of options within the "Market Depth Historical Graph" to deal with this kind of situation. The most direct are the options to define the "Highest Quantity for Coloring". Refer to the following and the item beneath it:
Market Depth Historical Graph: Value Type for Highest Quantity for Coloring
