Date/Time: Sat, 07 Nov 2026 19:11:51 +0000
gold suddenly shows big spike in daily chart using Sierra datafeed
View Count: 1599
[2014-11-02 11:44:19]
User59879 - Posts: 84
I just noticed a big spike in gold in my daily chart today http://www.sierrachart.com/image.php?l=1414928456111.png I am using Sierra datafeed. Delete & download did not fix it.
Date Time Of Last Edit: 2014-11-02 11:45:07
[2014-11-02 19:07:57]
This is the result of test or faulty data from the CME.
We have performed reset of this data on the servers.
On that chart select Chart >> Reload.
If that does not clear it, reconnect to the data feed with File >> Disconnect and File >> Connect.
And then select Chart >> Reload.
Date Time Of Last Edit: 2014-11-02 19:25:21
[2014-11-02 19:08:11]
ok - problem appears to have been fixed: delete & download now corrects this anomaly.
[2014-11-02 19:09:16]
thanks!
