Date/Time: Tue, 24 Nov 2026 17:08:59 +0000
Ability to Type to search in Study Field Removed
View Count: 308
| [2026-07-01 04:18:46] |
| User150671 - Posts: 80 |
At some point with a recent update the ability to search studies by typing in the study box was removed. Example to select Volume study: Typing consecutively 'V O L U' would highlight the Volume study. With recent updates now the result is the first study with 'U' as it's first character is highlighted using the same input. I was just accepting this, but I recently loaded up an old machine and without thinking did the previously standard 'V O L U' to select Volume and realized this is actually a lot more efficient method to select studies and I miss it. Can we get it back please? |
| [2026-07-02 20:24:36] |
| Sierra_Chart Engineering - Posts: 25476 |
This is an operating system level behavior. The sorting of the list is now implemented by Sierra Chart and because of this, this type of behavior no longer is supported because it just does not work. We did not know this would happen.
| [2026-07-02 20:28:18] |
What we are going to do is to add a proper search to the Available Studies list.
