Date/Time: Sat, 07 Nov 2026 19:01:48 +0000
Using Custom study files
View Count: 3388
[2014-11-02 11:08:20]
User38813 - Posts: 20
sir i am not able to use/run "kiwi7' file located in ASC code. a error ocurred as
"- Starting build of Custom Studies Source files: Rainbow.cpp. -- 16:26:23
None of the selected source files contains the SCDLLName line at the top of the file. Refer to ACSIL documentation.
-- End of Build -- 16:26:23"
Please guide me how to proceed from here.
If possible please change/build it into DLL. As studies is already there in Sierrachart> ACS source folder. I m not perfect in programming so facing lot of difficulty in changing this study
[2014-11-04 18:04:18]
You need to put the SCDLLName ("") line near the top of the CPP file. Refer to this page for complete information:
https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html
Date Time Of Last Edit: 2014-11-04 18:04:39
[2014-11-05 09:39:58]
sir already there
[img]http://imagizer.imageshack.com/img746/2420/Qd7BBI.png[/img]
[2014-11-05 11:13:59]
We cannot accept the image you have provided. It must be attached. Follow these instructions:
[2014-11-05 17:50:34]
file attached
Date Time Of Last Edit: 2014-11-05 17:52:12
attachmentkiwi7.cpp - Attached On 2014-11-05 17:49:05 UTC - Size: 107.23 KB - 864 views
[2014-11-06 04:35:49]
The top of the file is correct but being this is an older CPP file, it is not likely to compile without errors and correcting the errors is not within the scope of our support.
However, whatever studies that are in there you can find in Analysis >> Studies >> Add Custom Study>> User Contributed Studies.
