Date/Time: Fri, 25 Sep 2026 15:56:35 +0000
ACSIL - access to incremental Market-By-Order updates (per-OrderID add/modify/delete)
View Count: 307
[2026-06-25 19:26:04]
User453167 - Posts: 6
Is there any ACSIL access to the incremental MBO update stream (the per-order insert/update/delete actions you already process internally, the headers even define MarketDepthUpdateOperationEnum)?
Ideally a drainable buffer per call like sc.GetTimeAndSales, each record { OrderID, BidOrAsk, Price, Quantity, UpdateType, DateTime }.
If it doesn't exist, is it feasible / on the roadmap, and if not, is there a recommended way to track per-order changes within ACSIL?
Thanks in advance.
[2026-06-25 22:08:37]
Sierra_Chart Engineering - Posts: 24971
This is not supported and is not something we would do.
