Date/Time: Mon, 23 Nov 2026 08:08:42 +0000
Help needed
View Count: 772
| [2026-07-07 13:38:18] |
| User158093 - Posts: 17 |
Hi John, I'm not asking for all of that.. I'm asking for ONH and ONL for the time being.. Surely you can advice how to enable this? I'm not ask you to build the chart for me.. I was just showing how those are other lvls I'm interested in.. Can you help me get ONH and ONL enabled to show on the chart Thanks |
| [2026-07-07 14:13:59] |
| John - SC Support - Posts: 48610 |
How you do this depends a lot on how you want to view those lines on the chart. Here is one way to get them. In this case, you will have the lines extending through the chart until the start of the next time: - Add the "Initial Balance" study to the chart. - Set "Initial Balance Type" to "Daily" - Set the "Start Time" and "End Time" to the overnight session. - Set "Start End Time Method" to "Use Start/End Time" Refer to the following: Initial Balance For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-07 17:48:00] |
Thanks John, So here's the next question.. How do I do the study, what study do I use for the ONH & ONL I managed to get the ib to work, with the initial balance study.. Thanks, quite simple to do.. You mentioned on the previous email, the overnight start and end time's.. But on which study, a separate study or on the same initial balance study, can you clarify that for me please. Thanks |
| [2026-07-07 18:24:39] |
We are suggesting you use the Initial Balance study to get your Onveright Hight and Overnight Low. You can set the times in the Initial Balance for the onvernight session to get those highs and lows. The Initial Balance draws lines going forward in time through until the next beginning of the Initial Balance. We are not certain how you want these lines to display. If that is what you want, then you are done. If you want something different, then you would need to look into other studies to do what you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-07-07 19:03:00] |
Okay, thanks John. I done that, seems to be working.. Next thing, I want to see on the chart, open(rth open) and yesterday close, (rth ycl) Can we display this on chart, what/which study can I use for this? Then I would also like to have YHI and YLO, previous days high and low Thanks John |
| [2026-07-07 19:25:58] |
You are taking advantage of us. First you state that you just need ONH and OHL, but then you expand this to many other things, basically asking for what we initially stated - you are wanting us to do the work for you to match your chart to something you found. We can not help you further with this. You would need to contact one of the people at the following link for help like this: Sierra Chart Personal Assistance For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
