Date/Time: Fri, 25 Sep 2026 15:56:34 +0000
Point and Figure Charts
View Count: 208
| [2026-06-24 18:28:29] |
| UserJG - Posts: 13 |
Since I updated my sierrachart to new version, my Point and figure charts do not draw continous lines. I configured as pnf bars on main chart and used the pnf study to configure ie es tick size .25 x 9 reversal. When rolling back , to previous release, it works fine. |
| [2026-06-24 18:31:09] |
| John - SC Support - Posts: 48013 |
The "Point and Figure Study" is very old and should not be used. We would not be surprised if it is not working properly in a recent release. You should use the built-in Point and Figure options for the Bar Period and the Graph Draw Type. Refer to the second paragraph in the following link: Point and Figure Chart: Description For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-25 01:29:13] |
I still can not configure pnf chart showing ES with 9 tick reversal. Please advise. The bar period value remains 10-1 after i try to change it. Also I do not find the "ignore" field that is mentioned. |
| [2026-06-25 13:17:38] |
We are not seeing any issues with setting the Point and Figure parameters to a 1 tick box size with a 9 tick reversal. We wonder if you are entering the parameters as "0.25-9". This would not work. You need to enter it as "1-9". As to the "ignore" field, if you are referring to the Input for "Ignore Last Bar Until Completed" from the Point and Figure study, then this is not available with the built-in Point and Figure bar period. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
