Date/Time: Tue, 24 Nov 2026 02:33:07 +0000
Since the last udpate(s) I cannot use UP_BAVWAP and DW_BAVWAP
View Count: 447
| [2026-06-24 17:33:47] |
| User191029 - Posts: 14 |
Hello Support Since the last couple of version updates I lost the ability to use two Custom Studies that previously worked UP_BAVWAP and DW_BAVWAP Current version: 2922 Rev: 57220 Any thoughts pls? |
| [2026-06-24 18:11:59] |
| John - SC Support - Posts: 48633 |
Refer to the first note in this section and ensure you have updated your studies accordingly: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2897 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-24 18:46:29] |
Hi John Thank you for your reply The 2 studies referenced are part of the UserContributedStudies_64.dll v2551 Is this maintained by SC or each contributor needs to submit updated versions upon each release? Thanks |
| [2026-06-24 19:21:22] |
We generally do not do much with the User Contributed Studies, except a compilation once in awhile as needed. But given the changes that are occurring, we will see what Engineering wants to do about these.
| [2026-06-24 19:26:11] |
If ENG doesn't want to recompile them and not bound by any non-disclosure, can the source code be made available so we can compile it ourselves? I would contact the contributor, but I could not find any info As always, appreciate your assistance Thank you! Date Time Of Last Edit: 2026-06-24 19:26:44
| [2026-06-24 20:14:44] |
Most of the source code for User Contributed Studies is available at the following link: User Contributed Advanced Custom Study System Source Code These are the .cpp files that we were given to us, so the name of the .cpp may not match what you are looking for. For instance, there is no "UP_BAVWAP.cpp" file, so most likely that function is contained within some file, but there is not an easy way to search, so you have to just take your best guess. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-24 20:50:14] |
Hi John Got me on the right path and is now working for me I am uploading the CPP if it helps anybody else, or if it can be added for the eventual recompilation of the user submitted studies by the engineering team Thanks again! |
| [2026-06-25 05:30:40] |
| Sierra_Chart Engineering - Posts: 25470 |
We are rebuilding all of the user contributed studies for the next release.
