Date/Time: Wed, 11 Nov 2026 19:38:59 +0000
Which Denali DataFeed Option to choose for my Indicator
View Count: 399
[2026-06-24 15:38:03]
User999001 - Posts: 7
Hello There,
I am using Service pack 11 and looking to add the real time data feed from Denali but I do not know which options to choose as a Non professional (I already Qualify) between CME with Market Depth or Top of the book only.
I will be using only the charts, Market profiles and Cumulative Delta Bars - Up/Down Tick Volume only as I use another software to enter my live orders.
Question:
Will my Cumulative Delta bars indicator operate efficiently and on a tick by tick cases with "the top of the book" only option?
Will this same data feed option (Under Denali) be sufficient to display my Market profile + chart set up?
Thank you,
best regards
[2026-06-24 17:28:13]
John - SC Support - Posts: 48499
The only difference between the "With Market Depth" and "Top-of-Book" is the amount of Market Depth data that you get. With Top-of-Book you get just the 1 level for the Best Bid/Best Ask. With the "With Market Depth" option you get up to 1400 levels of Market Depth data.
The Market Profile and Cumulative Delta Bars (all options), do not use the Market Depth data - these are all based on the actual trades.
Yes. See above.
Yes. See above.
