Date/Time: Tue, 24 Nov 2026 21:27:26 +0000
[Programming Help] - sc.MakeHTTPRequest() to support Headers
View Count: 374
| [2026-06-23 01:25:50] |
| User339987 - Posts: 16 |
Would it be possible to have sc.MakeHTTPRequest() also able to submit header information like sc.MakeHTTPPOSTRequest() ? This is for submitting "Authorization: Bearer Token" Thank you. |
| [2026-06-23 22:01:40] |
| Sierra_Chart Engineering - Posts: 25476 |
We recommend at this time using sc.MakeHTTPPOSTRequest And just provide an empty string for the post data. Therefore, you have support for headers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
