Date/Time: Mon, 09 Nov 2026 14:58:18 +0000
Missing/incomplete historical intraday VOLUME on Denali feed — ES contracts, specific date
View Count: 672
[2026-06-22 13:41:13]
User833459 - Posts: 11
I have severely incomplete historical Intraday data on the Denali Exchange Data Feed
for the E-mini S&P 500 (ES) on specific dates. The TIME bars are present, but the
volume / number-of-trades is zero or a small fraction of the actual traded volume —
i.e. the tick-by-tick trade data for these windows appears to be missing from the
Denali historical archive.
Affected symbols / dates (CME, times in CT):
- ESU26 (Sep 2026): 2026-06-15 (evening), 2026-06-16 (entire day),
2026-06-17 (00:00–17:00)
- ESM26 (Jun 2026): 2026-03-17 (from ~16:00), 2026-03-18 (00:00–17:00)
The full data DOES exist at the exchange. I verified the same contracts/dates on an
independent CQG feed (in another platform), which shows full daily volume:
- ESU6.CME 2026-06-16 ≈ 1.8M contracts (Denali: volume bars essentially empty / 0)
- ESU6.CME 2026-06-17 ≈ 1.8M contracts (Denali: ≈ 157,000 RTH)
- ESM6.CME 2026-03-17 ≈ 1.6M contracts (Denali: heavily reduced)
- ESM6.CME 2026-03-18 ≈ 1.7M contracts (Denali: partial)
So the trades exist at CME; they are missing only from the Denali historical archive
for these specific windows.
Already tried:
- Edit >> Delete All Data and Download (full re-download) on the individual contracts
— the gap persists, and the re-downloaded data is in some cases even thinner than
my originally recorded live data.
- Intraday Data Storage Time Unit = 1 Tick (so this is not a local storage-resolution
issue).
- The gap is identical across all chart timeframes for these symbols (not chart-specific).
This appears to be the same class of issue you resolved server-side in thread 102071
("Daily/Weekly data missing from Denali exchange feed, even after delete and download").
Could you please check and correct the Denali historical archive for ESU26 and ESM26
on the dates above, so that a Delete-and-Download retrieves the full tick/volume data?
Environment: Sierra Chart 2922 64-bit; Denali Real-Time Exchange Data Feed + Sierra Chart
Historical Data Service; "Allow Support for Sierra Chart Data Feeds" = Yes.
Thank you.
Date Time Of Last Edit: 2026-06-22 14:48:15
[2026-06-22 15:25:30]
Sierra_Chart Engineering - Posts: 25406
No this is definitively not true:
Your conclusion is 100% incorrect. We know that with certainty. You may be comparing a Continuous Futures Contract Chart with a non-Continuous Futures Contract Chart.
We checked four of our servers for this symbol and date, and they all give consistent volume:
ESU6 Volume: 00:00:00 to 23:59:59 for June 16, 2026: 1080177
Date Time Of Last Edit: 2026-06-22 15:37:50
[2026-06-22 16:32:52]
Thank you — you are right that the intraday data is present, and I was wrong to
say the data is entirely missing. I have now isolated the real issue, and it is
narrow and reproducible:
The Historical DAILY data (volume) is incomplete for specific contract days,
while the INTRADAY data for the same days is complete.
Example — ESU26 (E-mini S&P 500, September 2026, CME):
- Intraday (.scid) for 2026-06-16 is complete and sums to ~1.8M contracts for
the day, in line with neighboring days.
- The Historical Daily (.dly) bar for the SAME day (and for 2026-06-15 and
2026-06-17) reports only ~0.2-~0.5M, versus ~0.9–1.3M on neighboring days.
- I deleted BOTH the .scid and .dly files and ran Delete All Data and Download.
The intraday came back complete, but the daily volume came back at the same
incomplete value. So the incomplete daily is coming from the historical
archive, not from a local file.
The same pattern appears for ESM26 (June 2026) on 2026-03-17 and 2026-03-18.
(Both windows coincided with a brief real-time feed interruption on my side; the
intraday was evidently backfilled correctly afterward, but the daily aggregate
was not.)
This matters because the Volume-Based Continuous Contract rollover uses the
Historical Daily volume to detect the roll. With the daily understated on these
days, the continuous chart rolls late and stays on the expiring contract through
them. Switching the same chart to a Date-Rule rollover then displays full volume
from the correct contract — confirming the intraday/contract data is fine and
only the daily aggregate is wrong.
This looks like the same class of server-side Historical Daily gap that was
corrected in thread 102071. Could you please check and correct the Historical
Daily data on your end for:
- ESU26 — 2026-06-15, 2026-06-16, 2026-06-17
- ESM26 — 2026-03-17, 2026-03-18
so that a Delete-and-Download retrieves the correct daily volume?
Environment: Sierra Chart 2922 64-bit, Denali Exchange Data Feed.
Thank you.
[2026-06-23 15:37:44]
John - SC Support - Posts: 48464
We are not seeing any issues with the Daily Historical Data for June 15 2026, June 16, 2026, or June 17, 2026.
For ESU26 on June 16, 2026, we get the following results
- Intraday Volume: 1087147
- Daily Historical Volume: 1792944
The Intraday data is accumulated starting on June 15, 2026 at 17:00 through June 16, 2026 at 15:59:59.
The Daily Historical volumes for the other days you note are the following:
- ESU26
-- June 15, 2026: 2150856
-- June 17, 2026: 1777601
- ESM26
-- March 17, 2026: 1648453
-- March 18, 2026: 1681048
If you do not have these numbers for your historical daily charts, then please redownload the data by selecting "Edit >> Delete All Data an Download" with that chart active.
