Date/Time: Tue, 03 Nov 2026 15:50:47 +0000
Bar Number candles
View Count: 1297
| [2014-10-31 22:34:42] |
| User46575 - Posts: 1 |
I have followed the instructions for installing the Bar Number candles but I can't figure out why they don't display correctly. Would appreciate any help. Thanks |
| [2014-10-31 22:57:02] |
You will need to use the study named "Numbers Bars". It is different.
