Date/Time: Sat, 26 Sep 2026 07:38:32 +0000
Notes column on DOM
View Count: 305
| [2026-06-21 20:28:29] |
| User165981 - Posts: 64 |
I know you were working on this, is it completed? Thanks |
| [2026-06-21 20:47:42] |
| Sierra_Chart Engineering - Posts: 24976 |
This is not yet supported even though you see the Chart DOM column setting. We will try to get some of this done this week.
| [2026-07-31 21:33:53] |
This is supported in the latest release. Here is the information about it: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2931 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
