Date/Time: Mon, 09 Nov 2026 11:52:10 +0000
VbP - Highlight Point of Control not functioning after update for Equities
View Count: 446
| [2026-06-21 16:03:23] |
| ChrisK - Posts: 54 |
Hello, After updating to version 2920 I’ve noticed that the point of control is not highlighting on volume by price volume profiles for many symbols on various timeframes and tick increments. TSLA Multiple profiles based on fixed time (Months & Weeks) at 40 ticks per volume bar does not highlight POC. PLTR Multiple profiles based on fixed time (Months) at 40 ticks per volume bar only highlights POC for a couple profiles. Same goes for daily timeframe VbP for TPO Chart when price increment in ticks set to 10. I haven’t cycled through all of my symbols but there is a clear issue with volume profiles in version 2920 for equities…POC used to highlight regardless of tick increment. For reference it looks like TPO Profile study does highlight all POCs when based on volume. The issue seems to be isolated just to VbP study. Please advise when resolved. Thank you. |
| [2026-06-21 20:51:08] |
Below are example screenshots of the issue... Notice here for PLTR, only the first VbP for TPO out of the 4 has the POC highlighted in orange: https://www.sierrachart.com/image.php?Image=1782074492527.png Notice here for TSLA, only 3 of the 9 profiles have the POC highlighted in orange. Some profiles will have POC extensions but not the POC highlight: https://www.sierrachart.com/image.php?Image=1782074513538.png Hope this helps clarify what I'm trying to resolve. Thank you. |
| [2026-06-21 22:03:44] |
| Sierra_Chart Engineering - Posts: 25406 |
We will check on this. It could be some kind of floating-point comparison issue.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-06-21 22:03:50
| [2026-06-21 22:09:48] |
Ok. Thank you.
| [2026-06-23 17:47:25] |
Just an FYI I experience the same POC highlight issue across all equity symbols ie PLTR, PLTR_MBO, PLTR-NQTV. Thanks for working to resolve. |
| [2026-06-24 04:48:25] |
This is resolved . We will put out a new release right now.
| [2026-06-24 10:36:00] |
I have updated to prerelease v2924 and it looks good now. Thank you!
