Date/Time: Thu, 24 Sep 2026 07:19:16 +0000
Market Depth is not working anymore
View Count: 248
[2026-06-21 12:08:55]
User699988 - Posts: 14
Dear Sierra Team,
I have Package 11 and would like to view the Market Depth for replay charts. Unfortunately, it only shows a single price level for both Buy and Sell, and the order count is always at 1.
In the "Customize Chart DOM Columns" menu, I have the following columns set to visible: Bid Size/Buy Column, Price, Ask Size/Sell Column. This used to work before. I don't recall changing any settings, but suddenly it is no longer working.
Thank you very much for your help in advance.
https://www.sierrachart.com/image.php?Image=1782043704623.png
[2026-06-21 18:09:01]
Sierra_Chart Engineering - Posts: 24949
Follow the instructions here to download historical market depth data:
Market Depth Historical Graph: Downloading Of Historical Market Depth Data
Also update Sierra Chart to the current version. This is important. There have been some changes related to downloading historical market depth data.
Date Time Of Last Edit: 2026-06-21 18:09:09
[2026-06-22 17:17:29]
John - SC Support - Posts: 47994
Additionally - You do not have an exchange active that includes the Market Depth data. Therefore, you are not going to get any market depth data automatically downloaded. As noted in post #2, you can get historical market depth data by forcing the download, specifically step #8 in the given link.
Also, be sure to review the information at the following link for how to replay market depth data:
Replaying Charts: Replaying of Market Depth Data
