Date/Time: Wed, 25 Nov 2026 01:19:47 +0000
Market Depth historical graph not working
View Count: 523
[2026-06-20 20:00:55]
User944318 - Posts: 65
I am attempting to attach the market depth historical graph study to a chart (/ES futures). I have service package 11 and get ES data and number bars without issue, however, when I attach this study, nothing happens.
How may I fix this?
[2026-06-21 03:48:48]
dbtrade - Posts: 24
This post has a HeatmapExample.Cht attached to it with a working Market depth.
Heatmap Improvements to be closer to Bookmap | Post: 331179
Load that up, set the symbol and see if it works for you.
Then you can move that study to your chart and start working through the inputs to get what you want.
If it doesn't work for you then it's possible you are missing some requirement?
Date Time Of Last Edit: 2026-06-21 03:50:45
[2026-06-21 15:10:23]
All other market depth/ level 2 studies worked for me. How did you get the chart to look like it does in the image?
[2026-06-21 18:09:11]
I am getting this message now: "Historical depth data download failed error downloading historical market depth data for ESM26. No market depth data files found for request"
[2026-06-21 19:50:56]
ticinotrader - Posts: 431
@User907968
Thanks for confirming. I apologize for my mistake and have deleted the post I made in this thread so as to not confuse anyone.
I cannot delete your quoted reply, though, so please edit it to remove what I wrote.
[2026-06-21 20:04:03]
dbtrade - Posts: 24
ticinotrader does have another excellent bookmap style chart somewhere in the support boards that I either downloaded at some point and lead to the confusions.
I see you are having data download issues. It may be required that you use the teton data feed. Or Denali,
Date Time Of Last Edit: 2026-06-21 20:45:29
[2026-06-23 16:59:37]
We are not certain if there is still an issue from the original poster. If you are still having an issue, please let us know what it is.
