Date/Time: Fri, 06 Nov 2026 12:49:50 +0000
Numbers bars leaving gaps on empty price levels
View Count: 286
[2026-06-19 21:47:41]
NorthernTrader_21 - Posts: 15
Hello!
Is it possible to display empty price levels on the numbers bars? Currently it just leaves a gap and doesn't show anything at all if there are no trades made at that price.
Volume filter settings "Exclude <=" and "Exclude >=" are set to 0 and "Filter Trade Completely" to No
I'm using 8 tick range bars on the ES.
[2026-06-20 01:20:06]
What would you want there to be at those levels?
[2026-06-20 01:41:10]
It would be easier on the eyes to read the numbers bars if they were continuous just like normal candlesticks, instead of looking at chopped up bars it should show 0 on the bid and ask with a perhaps a neutral color.
Can't really find any settings for this, perhaps this could be added on the next product release?
Appreciate any response.
[2026-06-21 14:43:46]
Sébastien - Posts: 156
A workaround to this problem is to use the study Highest High / Lowest Low over N bars
Set the length to 1 bar and the subgraphs to Fill rectangle Top / Bottom, then you'll have a background color for your bars.
[2026-06-21 20:06:46]
That'll work, thanks for the tip.
