Date/Time: Fri, 06 Nov 2026 12:49:52 +0000
SC Not responding
View Count: 236
| [2026-06-18 12:59:41] |
| User413987 - Posts: 4 |
Since the latest update anytime i close SC down it will hang for minutes not responding, or even deleting a chart from a chartbook. Any ideas what is happening or should i just go back to the prior version. |
| [2026-06-18 22:14:32] |
| Sierra_Chart Engineering - Posts: 25390 |
We do not observe any problem like this. This must be some kind of system specific issue. Try going back to a previous version but we do not know why there would be any difference. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
