Date/Time: Mon, 09 Nov 2026 14:38:55 +0000
Changing Color on Control Bar removed buttons.
View Count: 246
[2026-06-17 16:48:37]
User708541 - Posts: 209
Version 2920.
I was trying to experiment with different colors for my control bar. I changed Button Default Background to: 255,255,255. I hit apply and my Daily Net Profit/Loss button went away. I tried this 2X and same thing happened both times.
After that I didn't change any colors.
Also, after clicking Apply All to select the new color change, the Control Bar doesn't fully come back to it's previous state. I have 2 buttons to the right of the DPL button, Scroll Link and Mute All Alert Sounds and they don't graphically return after the color change, but they aren't physically removed like the DPL button. I can get the Scroll and Mute buttons to return by right-click in control bar region >> customize control bar >> then click ok. But I had to physically reload the DPL button as it was permanently removed.
[2026-06-17 22:18:30]
Sierra_Chart Engineering - Posts: 25406
We are checking on this.
