Date/Time: Mon, 09 Nov 2026 14:39:53 +0000
Large Volume Trade Indicator
View Count: 378
| [2026-06-17 07:12:51] |
| AKR - Posts: 548 |
Since I updated to most recent version - when I select "Marker Style" = none, then also the text is not displayed. that used to work and I did use it having the study twice, once for dots, once for the number next to it. Is that intentionally not working anymore? |
| [2026-06-17 14:21:52] |
| John - SC Support - Posts: 48464 |
We are not seeing any issue with the "Marker Style" set to "None" and having the numbers displayed, as long as the "Draw Volume Text" is not set to "None" as well. If you are still having an issue with this, then what are the main Inputs set to for this study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-18 06:29:01] |
| AKR - Posts: 548 |
whyever it works today. but I SWEAR it did not yesterday and also the numbers just disapeared on 2 of my charts using the study twice each after I updated to new SC version and I did not change ANYTHING on the settings. anyway. |
| [2026-06-18 06:35:18] |
| AKR - Posts: 548 |
I did change some settings in the one chart working today. I have an anotherone I did not touch. Figures still gone. I figured out the reason was that it was set to "use transparent draw style" = yes. I changed to NO - now its working. But I had that setting to "yes" also before the update ... so something must have changed. |
