Date/Time: Tue, 03 Nov 2026 15:51:33 +0000
(Horizontal line at time) question
View Count: 1358
| [2014-10-31 13:49:06] |
| User48557 - Posts: 138 |
I have a attached chart with the study (horizontal line at time). I noticed since the market is way above it , it makes my chart very small and unreadable. Is there a setting to fix this? Maybe so I can only see the line when its in my time frame?
| [2014-10-31 14:26:30] |
| Sawtooth - Posts: 4359 |
Set the Horizontal Line At Time study's Scale Range to 'Same as Region'
| [2014-10-31 17:08:45] |
I don't see in the settings where I could do that?
Attachment Deleted. Attachment Deleted. |
| [2014-10-31 17:45:15] |
On the Settings and Inputs tab of the Study Settings window press the "Scale" button.
