Date/Time: Mon, 09 Nov 2026 05:18:48 +0000
Historical Intraday Data Download Failed Error, permission denied
View Count: 242
| [2026-06-16 09:45:45] |
| JLaranjeira - Posts: 1 |
Hi having problem downloading historical data . The error is "Historical Intraday Data Download Failed permission denied". Dont know how to fix, i use windows firewall seams there is no issue and i even use port 80 . The only thing i did was update sierra but change to previous version and its the same. Thanks in advance |
| [2026-06-16 14:53:30] |
| John - SC Support - Posts: 48459 |
Refer to the following: Rithmic Trading Platform Service: Permission Denied Resolution Procedure For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
