Date/Time: Tue, 03 Nov 2026 15:51:51 +0000
Crosshair NOT visible
View Count: 1265
| [2014-10-31 12:42:49] |
| bwasi - Posts: 34 |
even though 2nd icon tool crosshair selected..see attachment
| [2014-10-31 15:46:22] |
Check the settings in Global Settings >> Tool Settings >> Chart Values. Select another tool in the Tools menu and go back to Chart Values tool and left click on the chart again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
