Date/Time: Fri, 06 Nov 2026 12:53:05 +0000
Different highs on Sub Instance and...
View Count: 196
| [2026-06-15 16:22:24] |
| User731023 - Posts: 167 |
I show different highs on Sub Instance. Also Main does not seem to be back adjusted even though selected. (See image) I have spent 8 hours trying to figure this out. Not happy. |
| [2026-06-15 19:14:44] |
| John - SC Support - Posts: 48449 |
We wonder if the back-adjustment did not calculate correctly for some reason. In the Sub-Instance select "Edit >> Delete All Data and Download". You will be presented with a selection of contracts to redownload, be sure to "Select All" to redownload all of the data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
