Date/Time: Fri, 06 Nov 2026 12:54:07 +0000
[Programming Help] - Footprint Numbers Bars Highlight Minimum/Maximum Lines width/color
View Count: 313
| [2026-06-14 22:58:58] |
| User303857 - Posts: 201 |
Is there any way to add a line study to the Highlight minimum & maximum values? So I could extend them across the chart or fill the areas above or below for the last bar? Using large range bars and time frames. I have them both displayed in column 2. But there are no sub-graphs ID:# available to build a sub-graph line study off of. Date Time Of Last Edit: 2026-06-14 23:08:57
| [2026-06-15 15:48:39] |
| John - SC Support - Posts: 48449 |
When you have the Highlight Minimum and Maximum options enabled for the Numbers Bars, then you can access those levels per bar using the "Price at Minimum Highlight" and "Price at Maximum Highlight".
