Date/Time: Sat, 24 Oct 2026 00:54:57 +0000
"Market Depth Combine Increment in Ticks" misalignment with "Horizontal Grid"
View Count: 287
[2026-06-14 19:47:45]
CocoBro - Posts: 1
I was wondering if there was a way to align the horizontal grid lines and the combined market depth so that the volume bars line up with the horizontal grid lines. For this picture, I'm using a 10-tick combined increment, a scale increment of 2.5, and a grid line increment of 2.5. It does the same thing with 8 and 12-tick combined increments with their matching scale and grid line increments. I have included a screenshot of what I mean.
Thank you!
imageNot-Extended.png / V - Attached On 2026-06-14 19:47:11 UTC - Size: 11.51 KB - 104 views
[2026-06-15 15:10:11]
John - SC Support - Posts: 48317
For the situation you are showing, since the grid lines are not being extended into the DOM, they are set to line up to the prices.
You can set the following option to have the grid lines extend into the DOM, where they will be offset in order to not cross the prices and will give you what you want:
Global Trade Settings Windows: Extend Chart Horizontal Grid onto Chart DOM (Global Settings >> Chart DOM Settings >> Other >> Other Settings)
