Date/Time: Mon, 15 Jun 2026 17:59:02 +0000
Attached Stop Order Rejected After Parent Fill Using Teton
View Count: 29
[2026-06-14 19:08:23]
User829413 - Posts: 1
I am using Teton/AMP routing to submit a bracket order to CME. The parent order was filled successfully, but the attached stop order was rejected with the following message:
Teton CME Routing (Order reject). Info: CME (Rejected). Text: Sell order stop price must be below last trade price.
According to the Sierra Chart documentation for Teton:
With some of the other supported Trading services, the bracket order management is on the client side with a much higher delay from when the parent order fills, to when the Target and Stop orders are transmitted. This can be for example 300 ms and higher, rather than below 1 millisecond when managed on the server as they are with this service.
The parent order fill is reported at 06:30:00.544, and the first trade below the stop price appears at 06:30:00.548.
My question is:
1- If Teton server-side bracket management normally transmits attached orders in less than 1 millisecond after the parent fill, why was the stop order not placed between 06:30:00.544 and 06:30:00.548, resulting in the exchange rejection? Is it possible that the stop order was transmitted before 06:30:00.548 and was waiting to be processed in the exchange?
2- Is there a way to get the exact Teton server timestamp when the attached stop order was transmitted to CME?
Order Information
Parent Fill Time: 06:30:00.544
Parent Fill Price: 29502.000
Attached Stop Price: 29499.000
Relevant Time and Sales Data
| Time | Price |
| 06:30:00.543 | 29502.000 |
| 06:30:00.543 | 29502.250 |
| 06:30:00.543 | 29502.500 |
| 06:30:00.548 | 29496.750 |
| 06:30:00.553 | 29494.000 |
| 06:30:00.555 | 29495.000 |
Order Submission Code
s_SCNewOrder buyOrder{};
buyOrder.OrderQuantity = 1;
buyOrder.OrderType = SCT_ORDERTYPE_STOP_LIMIT;
buyOrder.Price1 = buyStopPrice;
buyOrder.Price2 = buyStopPrice + stopLimitOffset;
buyOrder.TimeInForce = SCT_TIF_GOOD_TILL_CANCELED;
buyOrder.AttachedOrderTarget1Type = SCT_ORDERTYPE_LIMIT;
buyOrder.Target1Offset = targetOffset;
buyOrder.AttachedOrderStop1Type = SCT_ORDERTYPE_STOP;
buyOrder.Stop1Offset = stopLossPoints;
Date Time Of Last Edit: 2026-06-14 19:13:44
[2026-06-15 15:07:31]
John - SC Support - Posts: 46687
The account you have posted from is on a Trial, and therefore could not be the account from which you are asking these questions. Please be certain to post from your live account.
You are referring to a 5 millisecond situation. There are too many variables to be able to ensure everything is done within that tight of a window.
