Date/Time: Mon, 14 Sep 2026 16:38:40 +0000
Multiple Installation Trade Copier -
View Count: 385
| [2026-06-13 13:35:06] |
| HeyUgly - Posts: 285 |
Good morning I know there are a few third party products out there for this with multiple installations, but could sierra ever look into an option where you can trade multiple different accounts without having to run separate installations? Say for me - i trade prop firms. If i want to copy trade across 5 different prop firms, i have to have 5 different installations of Sierra running.... doable, but a but cumbersome and screen consuming. Is there a way to develop a protocol within sierra to have multiple logins connect and copy, without having to have all these installations running at the same time? I know I can do it with having the installations up, i already do this, but is there a way sierra could look into this? I have a community of 500 traders, and its literally the only holding back most of them getting sierra is this issue. There are products like tradesyncer etc, but man I always prefer to stay INSIDE sierra charts, because you guys do such good work...... anyways, though i would ask! |
| [2026-06-14 10:31:21] |
| User16876 - Posts: 16 |
May I ask what exactly is your current situation? How do you copy trades across 5 different SierraChart installations / prop firms? Do you use any 3rd party tool?
| [2026-06-17 12:36:01] |
i have 4 different installations of sierra charts open, and i use a trade copier i built. I have been trying to build something that doesnt require having all these installations up, but seems like it wont work.
| [2026-07-27 06:52:11] |
| User860690 - Posts: 12 |
probably you can custom code it. i have built a python that sends my trades to google sheet so i can run a performance dashboard. i think it works the same.
