Date/Time: Fri, 06 Nov 2026 12:55:13 +0000
Feature request: Side offset for Right aligned Volume by Price
View Count: 271
[2026-06-13 08:00:35]
mikrom - Posts: 12
I use this trick where I place another Volume by Price study to the right of my main VbP but make it invisible, just to take up some space and push out the main profile from the side, because I want to display a custom study on the far right side and don't want it to overlap with the profile.
This trick works, but it probably increases the workload of the chart unnecessarily (even if not noticeable). It would be cleaner if there was a dedicated input setting for setting a "side offset" instead. I hope you can consider adding this.
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=139342
imageScreenshot_20260613_094244.png / V - Attached On 2026-06-13 07:58:24 UTC - Size: 48.41 KB - 150 views
