Date/Time: Fri, 06 Nov 2026 12:55:13 +0000
Numbers Bar Calculated Value on Standard Candlestick Chart
View Count: 301
[2026-06-12 22:51:48]
jdrico - Posts: 6
Hello!
I am trying to display the numbers bar calculated values on a standard tick based/time-based candlestick chart. Is this even possible and if so, how do I go about doing this?
I don't get much use out of a footprint chart, but the values for each bar on it are invaluable.
Thanks!
[2026-06-15 13:23:21]
You can use the "Numbers Bars Calculated Values" studies on any kind of chart - it does not need to be a Numbers Bars chart. Just add the study to the chart like you would with any other study.
