Date/Time: Tue, 03 Nov 2026 15:52:04 +0000
ACSIL - Share some consolidated data between 2 Sierra Instances
View Count: 1327
| [2014-10-31 04:17:18] |
| ejtrader - Posts: 689 |
SC Team - I am trying to create some data in a consolidated form in one instance of Sierra and would like to share this in second instance of Sierra. Do you have any specific recommendation/pointers on this? One of the data structures I have thought through is shared memory map. Sierra Chart 1 - Would create/populate an STL map Sierra Chart 2 - Would only READ the contents of the above STL map Appreciate any suggestions/pointers in this regard. Thanks Date Time Of Last Edit: 2014-10-31 04:42:39
| [2014-10-31 05:21:49] |
Data sharing between processes is usually best accomplished through a network socket. Either TCP or UDP. Or you can use a data file. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
