Date/Time: Fri, 06 Nov 2026 12:55:58 +0000
New Sierra Chart Order fills not showing
View Count: 272
| [2026-06-12 08:38:19] |
| Lucas Muench - Posts: 26 |
Hello guys, since on a new sierra chart (no prior configuration), my order fills on the chart do not show on the next day. It is connected to ritmic. show order fills is selected. Whenever I close and re open the next day I can not see any executions anymore, its blank. Which global setting or other setting could cause that? Thanks! |
| [2026-06-12 14:42:16] |
| John - SC Support - Posts: 48449 |
Most likely it is one of the three settings starting at the following: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) Also refer to the following for how to display the Order Fills in general: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
