Date/Time: Fri, 06 Nov 2026 12:55:58 +0000
Activity Log
View Count: 299
[2026-06-11 19:00:37]
User573977 - Posts: 16
Hi guys
I am having an issue with a prop firm, a trade that I didn't open appeared in my account and blew it up.
I want to know if I can use the activity log to prove that.
This is the line:
ActivityType  DateTime  TransDateTime  Symbol  Note  OrderActionSource  InternalOrderID  ServiceOrderID  OrderType  Quantity  BuySell  Price  Price2  OrderStatus  FillPrice  FilledQuantity  TradeAccount  OpenClose  ParentInternalOrderID  PositionQuantity  FillExecutionServiceID  HighDuringPosition  LowDuringPosition  AccountBalance  ExchangeOrderID  ClientOrderID  TimeInForce  Username  IsAutomated
Fills  2026-06-10 17:57:04.000000  2026-06-10 17:57:04.000000  MESM6.CME    Rithmic Direct - DTC historical fill        12  Sell      Filled  7278.50    TPT5901283  Open      sod      0.00      Day    N
It is the only line that says "Rithmic Direct - DTC historical fill" and FillExecutionServiceID "sod".
I would really appreciate if you can tell me what those things means, as I can only identify that they are different to the other lines in the log.
I also attached the complete log.
Thanks in advance.
Regards.
Mauro
attachmentTradeActivityLog_2026-06-11.txt - Attached On 2026-06-11 18:59:15 UTC - Size: 555.19 KB - 124 views
[2026-06-11 19:41:53]
The fact that it states "historical fill" means that the data for that fill was added to your log sometime after the actual fill occurred. In other words, you received this information from Sierra Chart requesting order fills from Rithmic to backfill anything that was missing.
But, this does not say anything about where the order came from, just the time and date and the type (a sell order filled at a price of 7278.50 on June 10, 2026 at 17:57:04).
We are not certain what exactly you are looking for. If you feel that you did not open the trade, then this will not really be shown in your Trade Activity Log. Either the information will not be there, which doesn't mean anything as Rithmic is notorious for not properly reporting orders and fills; or the fill will show - such as what you show, but that just means there was a fill - it does not give any information on where it is from.
