Date/Time: Fri, 06 Nov 2026 12:56:00 +0000
Sub-instances stop trading after parent locks trading
View Count: 249
| [2026-06-10 18:42:13] |
| User238701 - Posts: 161 |
Hello, I have multiple sub-instances on my SC. I wonder if there is a way to keep the trading active on these sub-instances while locking it for the main instance? I use Teton for my order routing. Thanks |
| [2026-06-10 20:15:30] |
| John - SC Support - Posts: 48449 |
No. This is not possible with Sub-Instances that are started using "File >> New Instance". Those sub-instances are tied to the main instance and send the orders through that main instance. So however that main instance is setup is what the sub-instances will see. So if the main instance is locked, then the sub-instances will not be able to send orders through. But, you can have separate installations of Sierra Chart, which are completely separate. But, if you are trying to connect to the same account, then depending on what trading service you are using, you may not be able to do this (Rithmic, in particular, does not allow for multiple connections from Sierra Chart). Refer to the following: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-11 05:59:45] |
Even if I set the main instance to Simulation, I wouldnt be able to trade on the sub-instances, right?
| [2026-06-11 14:28:00] |
When the Main Instance has "Trade Simulation Mode On" enabled, and the sub-instances do not, then the trades from the sub-instances will be sent to the main instance and processed as simulation trades in the main instance.
