Date/Time: Fri, 06 Nov 2026 12:55:59 +0000
Historical Intraday Data Not Downloading Far Enough Back - MBTM2
View Count: 416
[2026-06-10 16:48:30]
User937378 - Posts: 3
Hello Sierra Chart Support,
I am having an issue downloading historical intraday data for the Micro Bitcoin Futures (MBT) continuous contract.
My setup:
- Service Package: 11 (Integrated Advanced)
- Data Service: SC Data
- Symbol: MBTM26-CME with Continuous Contract enabled
- Intraday Data Storage Time Unit: 1 Tick
- Maximum Historical Intraday Days to Download: Non-Tick Data = 2000, 1-Tick Data = 2000
- Chart Days to Load: 3000
The problem:
After performing Edit >> Delete All Data And Download, the data only goes back to early February 2026. I need the data to go back to at least 2022.
Steps I have already tried:
1. Set Non-Tick Data and 1-Tick Data to 2000 days
2. Performed Edit >> Delete All Data And Download multiple times
3. Continuous Futures Contract is enabled on the chart
The Date Range In File From field shows 2025-05-20 and I cannot manually change it as it is read-only.
Could you please advise what I need to do to download the full available historical data for MBT going back to 2022?
Thank you for your assistance.
[2026-06-10 16:52:22]
Everything you have done is correct, and you should be getting the data.
What is "Chart >> Chart Settings >> Symbol >> Continuous Contract" set to?
[2026-06-11 03:59:49]
It is set to "Continuous Futures Contract
[2026-06-11 04:00:48]
date rule rollover
[2026-06-11 14:26:03]
Please get us an image of your chart by following these instructions:
