Date/Time: Fri, 06 Nov 2026 12:54:38 +0000
TradeActivityLog Question
View Count: 298
| [2026-06-10 13:58:11] |
| coachted - Posts: 544 |
Regarding the TradeActivityLogs folder, does the binary file store UTC timestamps only, or is there a setting somewhere in the program? I am writing some code and am seeing UTC timestamps in the binary file, yet when I look at my trade activity from the trade activity menu choice under the trades tab, the time is not in UTC timestamp
| [2026-06-10 15:20:01] |
| John - SC Support - Posts: 48449 |
All dates in Sierra Chart are stored relative to UTC. So what you are seeing is correct.
| [2026-06-10 17:55:04] |
ok so i am looking to create a similar file as the binary file, one that updates live with each trade without having to save the file manually, but i want the file to have the exact info the trade activity log has..is this possible?
| [2026-06-10 19:03:33] |
If you are asking if the Trade Activity Log file format is available, then the answer is "no". But what you store into a file of your own is up to you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-15 19:38:36] |
how can i find the specific column headings to reference in my code?
| [2026-06-15 19:47:14] |
Refer to the information at the following link for what information is available through ACSIL: Automated Trading From an Advanced Custom Study: Getting Order Information For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
