Date/Time: Fri, 06 Nov 2026 12:53:44 +0000
More color gradients on number bars
View Count: 278
| [2026-06-08 21:03:32] |
| NorthernTrader_21 - Posts: 15 |
Hello! Is it possible to have more color gradients on the number bars for more granularity? Can I add range 4, range 5, range 6 etc... |
| [2026-06-08 21:55:46] |
| John - SC Support - Posts: 48449 |
There is no option for this currently. We have noted this as a Feature Request. We can not say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-08 21:58:39] |
Can I program this myself using ASCIL?
| [2026-06-08 22:03:55] |
Not directly in the Numbers Bars study. That study (along with a few other ones) does not have the code available. Refer to the following: How to Build an Advanced Custom Study from Source Code: Source Code for Some Built in Studies Not Available For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
