Date/Time: Fri, 06 Nov 2026 12:52:53 +0000
trade activity log is not getting the fills data
View Count: 348
| [2026-06-08 20:18:45] |
| RutuvedGCG - Posts: 2 |
I am doing a bar reply on a strategy. The Show Order fills on chart setting is turned on and I can see there are trades being taken. Although I am unable to get the fills data in trade activity log and statistics. I have selected the the appropriate setting as follows: Trade Activity Type : all activity Symbol : all symbol Trade account : all accounts simulation state : simulated Also i have put the following in my code sc.MaintainTradeStatisticsAndTradesData = true; Let me know if i am missing anything here. Kindly provide with all the checklist of parameters and setting that I should check for. |
| [2026-06-08 20:26:18] |
| John - SC Support - Posts: 48449 |
Are you looking at the "TradeActivity" tab of the Trade Activity Log? If everything else looks correct and you are still not seeing the fills listed in the TradeActivity tab of the Trade Activity Log, then there must be something else in the "DisplaySettings" that is causing the information to not show up. Perhaps the date range you have, or the "Notes" or something else. Refer to the following: Trade Activity Log: Common Instructions to Set Trade Activity Log Display Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
