Date/Time: Fri, 06 Nov 2026 12:54:38 +0000
Symbol instead of price right side values scale
View Count: 371
[2026-06-08 12:45:26]
User14953 - Posts: 268
Want to display the chart's symbol in place of price in the right side values scale.
[2026-06-08 14:20:17]
Sierra_Chart Engineering - Posts: 25390
This is not supported but you can turn off the price box:
Graphics Settings - Colors >> Chart >> Last Trade Price Box
This can be done individually for a chart instead of globally:
Graphics Settings
[2026-06-08 14:54:12]
Could this feature request be added to your list for consideration?
[2026-06-08 15:56:46]
We need more information on what you are wanting to do/see. As noted, you can turn off the price scale, and you can use the "Symbol Display" study to display the symbol anywhere on the chart.
So we are not certain of what you are wanting that can not already be accomplished.
[2026-06-15 18:03:17]
Want the chart's symbol display consistently in place of or additional and proximate to the default location used for price whether the window is maximized or tiled.
The display of price itself is not required.
Date Time Of Last Edit: 2026-06-15 18:12:45
imagesymbol proximate to price.jpg / V - Attached On 2026-06-15 18:12:39 UTC - Size: 6.44 KB - 86 views
[2026-06-15 19:41:01]
You can get what you want, but you have to set it up per chart.
To do this do the following:
- Add the "Current Price Line" study to the chart.
- Go to the Settings for the "Current Price Line" study.
- Go to the "Subgraphs" tab for the "Current Price Line" study.
- In the "Draw Style" for the "CPL" subgraph, select "Subgraph Name and Value Labels Only".
- Enable the "Value Label" option
- In the "Value Label" set the Horizontal Align" to "Right Edge
- In the "Short Name" field enter the symbol as you want it displayed.
- Select "OK" to close the Study Settings window.
