Date/Time: Fri, 06 Nov 2026 12:43:22 +0000
[FEATURE REQUEST] - Customize Chart Trade Menu - Buy/Sell Triggered Limit with Chase (Auto-Set)
View Count: 454
| [2026-06-08 04:51:00] |
| E1ite51 - Posts: 8 |
The existing Buy/Sell Triggered Limit (Auto-Set) order works extremely well and automatically uses the Trigger Offset configured in the Chart Trade Menu. I use it frequently and the functionality is excellent. I'd like to request the addition of a new Chart Trade Menu shortcut: Buy/Sell Triggered Limit with Chase (Auto-Set) The concept would be identical to the current Triggered Limit (Auto-Set) order, with one change only: After the trigger condition is met, instead of submitting a standard Limit order, submit a Limit Chase order. All existing Triggered Limit (Auto-Set) functionality would remain unchanged. Attached Orders/Brackets would continue to function exactly as they do today. The order would use the existing Chase Limit settings already available in the Trade Window. "Auto-Set" could automatically capture both the Trigger Offset and the Chase Max value from the Chart Trade Menu settings. This order type already exists within Sierra Chart's order-entry options for parent orders, so the underlying functionality is already implemented. The request is simply to make it available as a Chart Trade Menu shortcut, similar to the existing Triggered Limit (Auto-Set) commands. For traders who use Triggered Limit entries with attached brackets, this would be a significant quality-of-life improvement, allowing direct execution from the chart without requiring additional manual order entry steps. Suggested Menu Item: Buy Triggered Limit with Chase (Auto-Set) Sell Triggered Limit with Chase (Auto-Set) Since both the Triggered Limit and Limit Chase functionality already exist independently, this appears to be a relatively straightforward addition that would provide substantial practical value. Date Time Of Last Edit: 2026-06-08 04:56:14
| [2026-06-09 04:14:20] |
The order type works flawlessly from the trade window, but requires manual config of the entry and trigger price always. Auto-Set from the chart trade command menu would make it much more streamlined and useable, especially for those with consistent parameters that don't need to change it per order. Hopefully it should be a very quick and simple roll out to add this in the chart trade menu, as the order already exists fully natively in sierra chart.
| [2026-06-12 10:14:10] |
Any update on this? I've tried to create ACSIL scripts via AI, but they always bug out / fail to place the triggered limit chase order. Is there any way this feature could be added soon?
| [2026-06-19 04:38:02] |
Any feedback on this?
| [2026-07-06 04:53:58] |
I would really hope to see this added soon, especially as it already exists natively. Just a matter of adding the shortcut to the Chart Trade Command Menu.
