Date/Time: Sat, 06 Jun 2026 23:46:54 +0000
Market replay for Ask Bid size is not working (other things are replaying properly)
View Count: 15
[2026-06-06 21:51:06]
User434462 - Posts: 1
It used to work correctly last week, but it no longer works this week. I have not changed any settings and am using the exact same setup.
There is a market depth data file saved in the Data folder for the replay date, and all settings required for recording and replaying market depth data are enabled.
Replay is clearly working, since other DOM columns are being replayed correctly, including Total Volume, Bid Volume, Ask Volume, and Delta Total Volume.
The issue is specifically with Bid Size and Ask Size. During replay they behave as if only Level 1 data is available, showing just 1 contract at the bid and ask. Pulling/Stacking data is also missing.
This same setup was working correctly last week, and I have not changed any settings. Market depth data exists for the replay date, and all related settings are enabled.
I'm trying to understand why only the market depth related data (Bid Size, Ask Size, Pulling/Stacking) is not being replayed, while the rest of the DOM data replays normally.
imageScreenshot 2026-06-06 144432.png / V - Attached On 2026-06-06 21:45:40 UTC - Size: 56.35 KB - 5 views
