Date/Time: Fri, 06 Nov 2026 12:59:28 +0000
Missing Chartbooks 21 22 23 24 after accidental deletion
View Count: 323
| [2026-06-06 21:40:15] |
| User296528 - Posts: 27 |
Hello, I accidentally deleted Chartbooks 21, 22, 23 and 24 while trying to close windows. I did not intend to delete them. The Chartbooks disappeared and now I only see Chartbooks 14, 15, 16, 17, 18, 19, 20 and 25. Is there any way to recover the missing Chartbooks 21, 22, 23 and 24? Thank you. |
| [2026-06-06 22:26:16] |
| Sierra_Chart Engineering - Posts: 25390 |
There are backup Chartbooks available. Refer to: Chartbooks (Workspaces): Accessing a Backup Chartbook File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
