Date/Time: Thu, 26 Nov 2026 04:57:43 +0000
2 Issues in 2916
View Count: 346
| [2026-06-04 20:22:58] |
| User165981 - Posts: 66 |
On the DOM I have the Volume by Price study set to reset on RTH. Works fine in 2915 but 2916 shows from Overnight as well. Clock Realtime Study PRints the time but does not move when I change the settings.. This heppens even in 2915 |
| [2026-06-04 21:25:34] |
What is the "Volume Graph Period Type" set to for your Volume by Price study? And also give us any other Inputs related to determining the period. -- With regards to the "Clock - Realtime", what you are seeing is how it has always worked. Refer to the information for the "Initial Horizontal/Vertical Position" Inputs here (and the link they link to): Clock - RealTime: Inputs For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-04 21:46:23] |
Attached are screenshots of the settings
| Attachment Deleted. |
| [2026-06-04 21:46:43] |
File attached
| [2026-06-05 00:08:54] |
| Sierra_Chart Engineering - Posts: 25491 |
What are the Chart Session Times set to. We have worked on that particular Volume Graph Period Type, fixing an issue related to it. We did test it though. But maybe there is a scenario we do not consider. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-06-05 00:09:12
| [2026-06-05 00:25:15] |
Here's session times
| [2026-06-05 01:52:08] |
We see what the problem is. This will be resolved in the next release. This should be out, by tomorrow morning. This will be the prerelease .
