Date/Time: Thu, 26 Nov 2026 04:57:45 +0000
Level 2
View Count: 268
| [2026-06-04 17:24:32] |
| User862138 - Posts: 41 |
Good day, Would it not be possible to have a Level 2 indicators as what most other platforms have. Instead of having a Bid Qty and Bid Order and Ask Qty and Ask Order, just have one column on each side with the quantities. Regards Deon |
| [2026-06-04 19:02:49] |
We are not certain what you are referencing. If you want to have columns on either side of the Price Ladder one for the Bid Market Depth and one for the Ask Market Depth, then you can do this. Refer to the following for how to adjust the columns in a DOM: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-05 05:49:43] |
Thanks for the reply. See attached what I mean. Regards |
| [2026-06-05 13:19:11] |
You are correct, we do not have anything like that. We have noted this as a Feature Request. We can not say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-05 14:09:55] |
| Sierra_Chart Engineering - Posts: 25491 |
Is it just a case, where you want to be able to reorder and/or remove columns on the market depth window? We can add that capability.
| [2026-06-05 14:16:07] |
Hi - yes - instead of having 2 columns each for Bid and Ask, have only one column for each - less numbers to follow - Bid price and size and on the other side, you have Ask price and size. If possible, it would be very nice. Thanks Deon Date Time Of Last Edit: 2026-06-05 14:18:36
