Date/Time: Fri, 06 Nov 2026 12:59:29 +0000
Trade Management By Study
View Count: 292
[2026-06-04 13:57:36]
User476926 - Posts: 62
Have been using Trade Management by Study linked to ACS Control Bar button for ages. Not working at all in 2915?
[2026-06-04 15:57:30]
We are not seeing any issues with the Trade Management by Study study, or the use of the Control Bar button to enable/disable the option in version 2915.
What exactly are you seeing? What is happening? Are you getting any messages in your Message Log related to this when you enable the study?
[2026-06-04 16:37:48]
When I enable the study by pressing ACS button, nothing happens at all. Message log then gives:
2026-06-04 12:31:46.652 | Chart: MESM26_FUT_CME[M] #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'.
2026-06-04 12:31:47.264 | Chart: MESM26_FUT_CME[M] #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled.
2026-06-04 12:31:47.511 | Chart: MESM26_FUT_CME[M] #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'.
2026-06-04 12:31:48.499 | Chart: MESM26_FUT_CME[M] #1 | Study: Trade Management by Study | 'Trade >> Auto Trading Enabled' is disabled.
2026-06-04 12:31:48.746 | Chart: MESM26_FUT_CME[M] #1 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'.
But the chart does have "Auto Trading Enabled" and more than 1 second (my frequency) has elapsed as you can see above.
[2026-06-04 17:05:39]
According to your Message Log, the chart (chart #1) does NOT have "Trade >> Auto-Trading Enabled - Chart" enabled. Check that specific item - keep in mind that there are two separate settings - one for "Auto-Trading Enabled - Global" and "Auto-Trading Enabled - Chart". The "chart" option needs to be enabled for that chart to be able to use automated trading studies. Refer to the following and the item below it:
Trade Menu: Auto Trading Enabled - Global (Trade menu)
Date Time Of Last Edit: 2026-06-04 17:06:12
[2026-06-08 13:13:07]
My error, somehow in upgrade to 2915 the Global option became unselected. Thanks.
